L319 Panel Van restoration - L319-forum.de
Beitragvon Robjota » 25.07.2018, 16:46
Some photos of the area I've started work on. I don't know how long this will take as the day goes too fast. Happy with progress.
Seems to be a common theme for corrosion...right through to the dash panel/ glove box...4 layers of rust . :roll:
Re: L319 Panel Van restoration
Beitragvon Robjota » 06.08.2018, 14:14
some more pictures, sorry they're upside down..
Brad
Beitragvon Brad » 07.08.2018, 15:56
Nice work! :top:
Beitragvon Robjota » 07.08.2018, 18:43
Thanks Brad...keeping me out of trouble for sure
Rob :)
Beitragvon Robjota » 10.08.2018, 10:46
Some more pictures...admin pls advise if this is a hosting problem.
Beitragvon Elo » 10.08.2018, 12:00
Hello,
the wrong orientation is a softwareproblem, it takes a look at the exif-data and there seems to be data that gives wrong information.
I have rotated the pictures but I think one is getting lost.
btw. nice work, keep us up to date.
Beitragvon Robjota » 10.08.2018, 12:15
Thanks Michael...
Google search tells me it's a common problem. When taking landscape photos on android phone...to keep capture button on right (volume buttons at bottom of screen) . . Cheers for the help.
Rob
Beitragvon Robjota » 15.08.2018, 14:47
This is my attempt to recreate the top frame that supports the door pillar and the roofline. It took a couple of attempts but I feel this will work.
Its two pieces welded together as Im using very primitive techniques, (in this case, two pieces of angle iron, some clamps and hammers/welder) I do concede to using a swaging machine to create the step.
Ive not to replicate the Gutter fold as its will be less complex and more flexible if I make the closing lip separately as necessary..
Beitragvon Robjota » 16.08.2018, 14:24
Hi everybody across the world...can you tell me is this lead work from the factory. Above door post and bulkhead frame. ? Looks to be simply to hide panel laps / spot welds. Thanks in advance
Rob
Zuletzt geändert von Robjota am 16.08.2018, 15:18, insgesamt 1-mal geändert.
Beitragvon Robjota » 16.08.2018, 14:32
Rob
Beitragvon zehbeh » 17.08.2018, 08:06
Hi Rob,
as far as I know there was used lots of lead in the production of 319s. So its quite likely that the position you mentioned also is leaded from factory.
Btw: great work you are doing on your panel. Looking forward for more pics.
Beitragvon zehbeh » 20.08.2018, 22:13
Hi Rob,
If you are interested in seeing some 319s, you have to go to the Dorset steam fair. You will find 4 319s there and maybe can talk to the owners.
Beitragvon Robjota » 20.08.2018, 22:43
Hello Christian
Many thanks for your kind words.
We may take a look at the Steam Fair, it'd be good to see some complete and working L319's, I'll take my tape measure :)
regards Rob
Beitragvon zehbeh » 21.08.2018, 10:02
Rob, I'll send you the phone number of Reinhard by PN. Then you cyn contact and meet him.
Beitragvon Robjota » 21.08.2018, 10:13
Thank you Christian, I'd appreciate that..
Rob
Mitglieder in diesem Forum: 0 Mitglieder und 7 Gäste
