L319 Arrival Across the Water - L319-forum.de
Forumsregeln
Beitragvon Robjota » 01.02.2018, 19:26
Hello to All 319 Enthusiasts
Finally after much researching and communications, my L319 is due to arrive this evening on Transporter.. I don't want to Jinx anything by being premature but I've waited this long (6 months) so fingers crossed..
It's a 67 model with the later diesel engine OM621 ? I think, Panel van and its got serious corrosion, particularly around the front A & B pillars and roof guttering..
Much as I'd like to be working on it, I'm currently building a workshop to house it properly ...
Much regards
Rob
Re: L319 Arrival Across the Water
Beitragvon Robjota » 23.04.2018, 18:57
Hello All
A good day for me today, as I managed to spend a few hours on the Van, she now runs and moves under her own power. Had to work on the priming pump - new O ring, (if anyone know where you can buy one of these pumps new OM621 ??)
Currently just running briefly as the radiator has a hole in the matrix but the engine sounds pretty sweet..
https://youtu.be/fZaHlpEMgto
Beitragvon panzerjim » 24.04.2018, 06:54
it's aliiiiiive !!!!!
good job and courage for the rust !!! :klatsch: :klatsch: :klatsch: :top:
Beitragvon Robjota » 24.04.2018, 08:28
Thanks Jim... I've seen worse I think
Removed the skeleton from the engine so it should smell better inside...
Zurück zu „Eure Fahrzeuge und die Besitzer“
Mitglieder in diesem Forum: 0 Mitglieder und 11 Gäste
