Beitragvon Brad » 02.08.2016, 15:56
See picture below. The brake drum and hub are all one. Undo the bolts of the hub to remove the axel shaft (axel shaft numbered #65 on diagram). Be careful removing the axel shaft from the hub as there is a gasket.( #66 on diagram). If you break the gasket dont worry as they are cheap to replace. Slide the axel out and store it in a clean environment. Now you are able to take the rear drum off by giving it a hit or two. Dont worry about the pictures of the bearings etc (#59 to #53) as they will all stay in place. Remember that the break drum is heavy.
