Reifengröße - Dimensions of the tires - L319-forum.de
Jean-Manuel
Beitragvon Jean-Manuel » 29.09.2015, 10:10
Hello !
I want to change the tires of my L319D "PritschenWagen" of 1966, but I don't know the correct size. My L319D has 3 sizes of tire on its wheels : 6.50, 7.00 and 7.50...
I tried to search the information on the forum but as I don't read German :oops: and the google translations are bad :roll: , I didn't find it...
Can anyone give me the correct dimensions for the tires, or give me a link where to find them ?
Thank you. :wink:
Aloisius
Re: Reifengröße - Dimensions of the tires
Beitragvon Aloisius » 29.09.2015, 10:41
Dear Jean-Manuel,
the normal sizes for the wheels are 6.00 or 6.50.
if you have the small/slim version of rim you have to use the 6.00
If you have the "bigger" version of rim it is up to you.
regards Manuel
Jean-Manuel
Beitragvon Jean-Manuel » 29.09.2015, 10:52
Thank you for this first answer ! :D
But I don't know which rims are on my L319D... :oops:
Now, another question : how can I know which rims are on my "PrischenWagen", slim or "bigger" ?
Maybe my L319D has two dimensions of rims...
Aloisius
Beitragvon Aloisius » 29.09.2015, 11:11
if they are riveted you have the small one.
Jean-Manuel
Beitragvon Jean-Manuel » 29.09.2015, 11:15
Thank you for this second answer ! :klatsch:
Most of the rims are riveted (maybe only one or two are not), so my PritschenWagen has the slim rims. :wink:
Conclusion : the correct size of tires for my L319D is 6.00. :D
Aloisius
Beitragvon Aloisius » 29.09.2015, 11:47
If you need wheels you can ask
http://www.kainzmaier.de/index.php/en/
Jean-Manuel
Beitragvon Jean-Manuel » 29.09.2015, 13:52
Thanks again !
I've already noticed this commercial website that will be very usefull for me in a few months I suppose, when I'll start reconditioning my PritschenWagen... Fenders, etc.
Beitragvon panzerjim » 29.09.2015, 20:38
je repond un peu en retard mais sur le mien toutes les roues sont en 6.00 . si jamais tu as besoin de jantes, fais moi signe, j'en ai 14 au total :scheinheilig:
i answer a little bit late but on my 319, i'm in 6.00 . if you need rims i've got 14 of them :scheinheilig:
Jean-Manuel
Beitragvon Jean-Manuel » 29.09.2015, 22:55
Well,I've had a look over the web on french commercial website: it seems impossible to find 6.00R16C tires...
Has anyone an idea where to find them and at which price ?
Is there an equivalent for the size, as for example 155x80R16 ?
@panzerjim
Thank you for your proposition, I'll tell you if I need rims.
First I have to check how many wheels are not riveted.
Beitragvon panzerjim » 30.09.2015, 07:07
sinon la solution la plus silmple reste de monter du 6.50R16. beaucoup plus courant comme dimensions et je ne pense pas qu'au control technique il verra la difference .....
the easier solution is to mount 6.50R16 tyres. it's easier to find these diumensions and i think that at the technical control he xon't see the difference .....
Mitglieder in diesem Forum: 0 Mitglieder und 0 Gäste
