Schiebefenster - L319-forum.de
Schiebefenster
Ari
Schiebefenster
Beitragvon Ari » 28.06.2020, 14:43
Hallo,hallo, möchte noch eine kleine Anfrage loswerden,
ich suche für mein kleines 319er Hochdach noch 2 sehr schmal gehaltene Schiebefenster mit Einbaurahmen, vielleicht hat einer von Euch da eine Idee , bin für jede Spur dankbar ,
mit besten Grüßen Ari
Wipo
Re: Schiebefenster
Beitragvon Wipo » 28.06.2020, 17:22
bootfenster?
Ari
Re: Schiebefenster
Beitragvon Ari » 28.06.2020, 22:27
Vielleicht da mal schauen, gute Idee danke !
Re: Schiebefenster
Beitragvon Robjota » 28.06.2020, 23:10
Ari
Re: Schiebefenster
Beitragvon Ari » 29.06.2020, 13:17
Hallo, Robjota,- super Tip, danke , die haben ja auch ganz kleine !!
Grüße , - Ari
Re: Schiebefenster
Beitragvon Robjota » 29.06.2020, 16:37
Hi Ari.
I have not dealt with them but happy to help if you need to enquire.
It says they make any size ! If you want me to ask for you...send me a private message.
Regards Rob
Ari
Re: Schiebefenster
Beitragvon Ari » 30.06.2020, 15:07
Dear Rob, thanks for your Help, my English is very simple , also understanding sometimes too difficult, but !!!
I Need two or, if not too expensive, four Windows to open from left to Right or opposit direction,
in Alu like Mill finished & clear glass like your Picture , which i can fix from the Outside .
I do not understand, what they mean by " Offside " or " Nearside " and the Size must be under 23 cm ( unfortunately I have only a clear height / Level between the upper and lower Frame of 23 cm )
in High and about two Peaces in 40 cm width & Maybe two Peaces in 60 cm width ( The height is Always max. 230 mm ),
i`m thankful, that you try to help me
Ciao Ari
Re: Schiebefenster
Beitragvon Robjota » 30.06.2020, 20:00
Hi Ari
I've asked a series of questions to the seller.
Nearside & offside in the UK refers to the side nearest the kerb when driving on the designated lane (so for me nearside is always the left side as I look out of the windscreen in the UK, whether lhd or rhd car)
..its to stop people saying left or right which in itself is a useless term relating to cars because the question is always followed up with "do you mean when I'm sat in the car or looking at it?" :D
I'll private message you when I get an answer.
Cheers
Ari
Re: Schiebefenster
Beitragvon Ari » 30.06.2020, 20:22
Dear Rob, Little bit difficult to understand but i think, when i take one window offside & one Window Nearside i can install both in the Right Direction, because of Wind and Rain.
I´m glad to contact you , my E-Mail adress is : haraldschickel@gmx.de ,
see ( Hear you ) with best Wishes
Ari
