I cant get rear drum of - L319-forum.de
johnny_jacobsson
Beitragvon johnny_jacobsson » 24.01.2017, 13:34
I have removed the drive shaft and i have bang the drum and it stuck, is ther anny more like berings or some thing i have to remove in the hub, or is it anny bolts in the back that is hold it in place?
Re: I cant get rear drum of
Beitragvon brizzel » 24.01.2017, 17:59
Hallo jonny_jacobsson,
have a look here:
First turn down the excenters that you can always turn the drum. Then you remove the No. 2 up to No.5. Now you can pull down the drum.
good luck
johnny_jacobsson
Beitragvon johnny_jacobsson » 24.01.2017, 23:36
I do not get the pic. Is 2-5 in the bering hub or? So i most remove the berings or is it in the other end? This is how it looks in may rearaxel is that a big nut or?
Beitragvon Harald2 » 27.01.2017, 04:19
Hello Johnny,
the next step is to remove the two crown nuts. You may need a puller to dismount the drum after this, but normally you can pull it off from the axle.
319 regards
Harald
Mitglieder in diesem Forum: 0 Mitglieder und 17 Gäste
